Mufflers
Old 03-01-2004 | 09:16 PM
Mr. Demeanor
Cant view the pic but are these the corkscrew type baffles? If so, I had them in my boat and picked up several MPH by cutting them out. Stock 330hp 454.
Old 03-01-2004 | 09:28 PM
Payton's Avatar
Charter Member #927
On CP perfpramance's website under the muffler section the have a test on a 25' Daytona with a 502 mag. The boat did drop 12 db, but it also dropped 200 rpm.
Payton is offline
Old 03-01-2004 | 09:31 PM
Payton's Avatar
Charter Member #927
The Hardin Marine one at the top looks the same as the double X.
http://cpperformance.com/products/Exhaust/024.htm
Payton is offline
Old 03-02-2004 | 12:15 AM
splashandburn's Avatar
Originally posted by Pantera572
Tried a set on a 305 chevy in a small Donzi. Worked well. Took off some of the harsh sound.
Don't think I would try them on much higher HP applications.
Just bought a set of GGB muffler tips for a
Merc 525. Designed for high HP motors.
Will be posting photos and results in about a month.
Greg
Do you have a wesite or phone # for them?
splashandburn is offline
Old 03-02-2004 | 08:54 AM
outriggers's Avatar
Default slip-ins
I installed a pair that look the same as in the pic, If I remember right I got them from Rex Marine. They seem to work well for me. I had to do something,I think it sounds good. I'm still not sure how it would do on a db meter and I don't think it would get the approval of most tree hugger types. I will say,I do boat where there a little sensitive and nobody's bothered me so far. As for performance loss I only ran it on the trailer without them. But I feel the boat performs as it should with a stock 7.4.
outriggers is offline
Old 03-02-2004 | 09:09 AM
290PQ
I tried them on my 502 mag. and lost 200 rpm, and also the tailpipes got so hot you could even touch them normaly they are only warm to the touch. I drilled a bunch of holes in the center plate and that helped a bit, but i only use them when there is a chance of a problem.
They do cut the noise down quite a bit.
Old 03-02-2004 | 02:18 PM
I inquired about the same mufflers at CPPerformance. They said 100-150 rpm loss. I said No Thanks.
Griff is offline
Old 03-02-2004 | 05:26 PM
Splashandburn,
GGB advertises in the classifieds under exhaust.
They also have a website. GGB.CA. I think.
Wait a while for it to load.
Greg
Out There is offline
Old 04-14-2004 | 03:04 PM
Bam Bam's Avatar
Greg
Pantera572, did you complete the installation of these mufflers yet? If so, have you had a chance to try them out and which ones did you buy, the Extreme Variable Exhaust for the High Flow Louver?
Bam Bam is offline
Old 04-14-2004 | 07:22 PM
Bam, Bought the extreme variable.
Looks like it will be done in two
weeks. I'll post pictures and my thoughts asap.
