Mirage conversion to ACCLERATOR >
Old 03-08-2004 | 09:04 AM
HOUSTONPROP's Avatar
Default polishing of most anything
here is a skegguard we removed the stabilizer fin and welded it solid. we polish and weld alot of different items.
HOUSTONPROP is offline
Old 03-08-2004 | 02:13 PM
jspeeddemon's Avatar
There is roughly a speed gain of 1.5 mph per 100 RPM increase across the board assuming an equal amount of prop slip. As Darin knows that prop and water relationship is akin to a ring and pinion with a variable of slip. If your speed does not increase equal to the RPM increase, then you have more slip. That is a round about answer to your question. As far as the ancient Chinese part I don't know, he is the expert on that.
jspeeddemon is offline
Old 03-08-2004 | 02:27 PM
splashandburn's Avatar
Default Re: polishing of most anything
Hey Darin,
I have (8) 4" x 8" stainless steal plates that I need polished - they are currently in the rough stage - is this something that you can do??
splashandburn is offline
Old 03-08-2004 | 03:23 PM
Default polishing
yes ,no problem as long as it's not 4'x8'
send me a picture or just ship away,we will be as reasonable as we can on cost,just depends if they require any welding ,and have a lot of foreign object debris marks.
also what is the thickness? any idea
Old 03-10-2004 | 03:50 PM
Default ROBY1
Thanks for you return on your prop,sorry you had a mishap,but we will put it back to the original ACCLERATOR design.
Old 03-11-2004 | 06:59 AM
ACCLERATOR DELIVERS,holeshot,midrange and top speed
.Custom Finished By Houston Propeller.
Old 03-15-2004 | 11:04 AM
Thumbs up SCOTT/tyson1234567890
Thanks for the prop,we recieved it today for the ACCLERATOR conversion ,it will be shipped back asap.Darin
Old 03-31-2004 | 10:43 AM
Default Bravo-one labbed
four blade Bravo-ones labbed,Houston Prop
(satin finished)
Old 03-31-2004 | 10:49 AM
JimV's Avatar
Darin,
I'm sending one out today
JimV is offline
Old 03-31-2004 | 01:05 PM
Panther's Avatar
Frank's Marine Service
Is there anything to be gained in midrange? I know that labbing typically increases top speed but sometimes you loose cruise speed.
I am running about 51mph at 3600, and 75-77 mph (depending on the load, temp etc) at 5050 rpms.
The motors are designed to run up to about 5200-5300. What kind of gains can I expect across the board. I am running 25P Mirage Plus in a, 86' Scarab Panther with TRS drives.
Merc recommended that I may want to try a set of 27 labbed mirage plus to keep the cruise speed up and gain a little bit on the top end. What do you think of this idea? I am affraid of bigger props on these TRS as I have blown lowers twice.
Panther is offline
