Mirage conversion to ACCLERATOR >
Old 03-31-2004 | 02:43 PM
  #31
HOUSTONPROP's Avatar
Default Panther
Panther there is nothing but all good to be gained on The ACCLERATOR keep with the 25's The holeshot,midrange and top end is increased.
Jim V- I will call you when it arrive to get instructions,Thanks Darin
HOUSTONPROP is offline
Old 04-01-2004 | 10:23 AM
  #32
Panther's Avatar
Frank's Marine Service
Can you PM me the cost.
Panther
Panther is offline
Old 04-01-2004 | 10:29 AM
  #33
Lightbulb Panther
you have mail from,
HOUSTON Propeller>Thanks
Old 04-03-2004 | 04:06 AM
  #34
BAD-HABIT's Avatar
Darrin Just a few questions....First off I have a Ballistic prop and notice some things that look similar. What can I expect to gain with the accelerator design applied to a ballistic? Also I have a BRAND NEW 17" Mirage Plus that I have no use for. I think the dia. Is way to large for my app. I get my best slip# with a 21p Mirage but it has a solid hub(which I don't really want) and the Mirage is a DOG in holeshot and acceleration. I do get my top speed though but I can only pull about 4600 out of it and need about 5300. Can my 17" Mirage Plus be worked to give me the holeshot/acceleration of my 17" Ballistic and still pull the rpms I need? I can email you with more detailed info if needed.
Randy
"Bad-Habit"
BAD-HABIT is offline
Old 04-05-2004 | 11:25 AM
  #35
Default Bad Habit
Randy we can work the 17 Mirage up to a 19 pitch and change it to our ACCLERATOR design which will work great and pull the rsssssssssssssssssssssss you need ,give me a call and we can talk more in detail,Thanks Darin
Old 04-05-2004 | 12:14 PM
  #36
dyno's Avatar
Charter Member #655
Darin can you do the conversion to a Plain Mirage solid hub? or does it have to be a +????
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-05-2004 | 01:03 PM
  #37
Default Dyno
Yes,WE CAN ,the Mirage is thinner to start so it make it a little easier on our part but the performance will turn out the same.
Old 04-05-2004 | 01:10 PM
  #38
dyno's Avatar
Charter Member #655
shoot me a Price......pair of 23 Mirage's converted to Acclerators...
dyno is offline
Old 04-05-2004 | 02:15 PM
  #39
Default Dyno
yes you have mail,
there is a couple of options ,satin or polished finish.
Thanks Darin
Old 04-05-2004 | 02:20 PM
  #40
tssteph's Avatar
Darin,
As soon as I get time to run mine I want to have you do my props. I need to know wht my RPM and speed is before I send them. They are 23 pitch mirage pluses right and left. What is typical turn around time and a cost? Thanks
Brian
tssteph is offline
