whats the trick? >
whats the trick?
whats the trick?
Old 03-07-2004 | 11:16 AM
KH0302's Avatar
Default whats the trick?
I can't get the seawater pump bracket bolt back in, am I gonna have to pull the water pump or does someone know a trick? Please help me...sob...
454 Mag motor
signed, busted knuckles from hell
KH0302 is offline
Old 03-07-2004 | 11:32 AM
RedDog382's Avatar
Which bolt on which bracket (there are two brackets)?
RedDog382 is offline
Old 03-07-2004 | 12:22 PM
KH0302's Avatar
The one that's just about behind the lower hose nipple.
KH0302 is offline
Old 03-07-2004 | 01:22 PM
marinetrans's Avatar
Pull off the circ. hose and try it. The bolt is a short 7/16 and Merc makes a special one w/ washer built in.
marinetrans is offline
Old 03-07-2004 | 02:29 PM
KH0302's Avatar
Well I wish I had the Merc bolt and not this POS that 1/2ass jackleg "mechanic" put on it. I'm going to have to pull the pump. What I have doesn't even have a washer. He'll NEVER touch my boat again. The reason I'm even F***ING with that bolt is because 1/2ass put the wrong belt on it and my engine ran hot. 2+" of slack in the belt at the full extension of the bracket, which appears to have been drilled on to make more room, and I suppose because it didn't have a washer is why it had THREE inches of slack when it ran hot.
Back to the dock...
I don't mean to rant on you guys, I'm sorry.
EDITED BY SELF
KH0302 is offline
Old 03-07-2004 | 03:35 PM
blue thunder's Avatar
I hate to tell you this KH but you don't need to take that bolt out to adjust/remove the belt. Only crack it loose with a 5/8" wrench... doah. How did you get it out?\
BT
blue thunder is offline
Old 03-07-2004 | 06:58 PM
KH0302's Avatar
I found that out when I figured out I had to pull the water pump pulley anyway.
doah? What's that mean?
KH0302 is offline
Old 03-08-2004 | 11:37 AM
The trick is to drop the bracket below the bolt hole, start the bolt without the bracket in place, screw bolt about 1/2 way in, then slip the bracket over the bolt head. The hole on the bracket should have a tear drop shaped hole to accomodate this.
Doah is just an expression used when one just does something that one wishes he had not
BT
Old 03-08-2004 | 05:49 PM
KH0302's Avatar
Oh you mean DOH!
My Skater buddy was helping me and he took the bolt all the way out. This bolt's too long I'm going to get the right one tomorrow. Got the port side header on---NOW I know that you MUST get the back bolt on #1 started before you do crap else. Dammit man!
These headers fit the boat perfectly, the 90 pipe butts up right to mr. collector. Saweet!
My stock exhaust had 2 hoses each but the headers have a plug in the collector hole, I guess(hope?) I can get a nipple to screw in that hole easy enough at Home Depot or the marina maybe?
Thanks for your help fellas.
KH0302 is offline
Old 03-08-2004 | 11:43 PM
You can get the nipple at many hardware stores. Get brass ones.
3/4 NPT with a 1" hose connection.
Griff is offline
