-   -   Bravo Question (https://www.offshoreonly.com/forums/general-q/73542-bravo-question.html)
CRD 03-08-2004 02:40 PM
Bravo Question
If a B1 is listed as "High Perfomance" does that mean it is a XR drive?
The only other info. I have is a part number OL747965 and it is a 2000 model year .
The drive has no other markings.
Thanks!
JaayTeee 03-08-2004 05:44 PM
XR's usually are labeled so on the
rear of the upper unit.
Externally looking at them,
XR's and XZ's have a larger diameter
prop shaft than the X ( or pre "X "rated ;)
drives)
Back in 98', Mercruiser came out
with the low water pick up lower unit.
They labeled drives with the low water
pick up lowers as "High Performance".
My guess, this is what you have.
jt
CRD 03-08-2004 07:01 PM
Thanks for the input, I thought it might be marked as high performance because of the low water pick up. Was hoping it had the larger shaft and gears...........
