x-dim
Old 03-10-2004 | 04:06 PM
aero-offshore's Avatar
What's the thought on k planes or trim tabs?. I know I'd be able to have better control, but what about speed increase? is it a bandaid cure for the wrong x-dim?
aero-offshore is offline
Old 03-10-2004 | 04:13 PM
BRUCE SEROFF's Avatar
Trim tabs will not help to gain speed. They will only slow you down when they are in the down position. Yes they will help keep the nose down in the rough.
BRUCE SEROFF is offline
Old 03-11-2004 | 09:09 AM
I HAVE A BRAVO WITH PERFORMANCE 1.36 GEARS AND AN IMCO 2 INCH SHORT LOWER YOU CAN HAVE FOR $2000 .USE THE LOWER AND KEEP THE UPPER AS A SPAIR.THE 1.36 OR 1.50 GEAR CHANGE IS IN THE UPPER IN THIS DRIVE.ADD ANOTHER $1000 AND GET THE EXT BOX WITH WING PLATES FOR STEERING.ALL FOR 3K
z.zuperboat is offline
Old 03-11-2004 | 12:39 PM
That's what I'm using 1:36, but I'll still be at the very least 1" to deep. Do you have the trim extentions for that box?
Old 03-11-2004 | 05:50 PM
Try a blackhawk drive. It is short enough to get you where you want to be.
cobra marty is offline
Old 03-12-2004 | 08:38 AM
Who manufactures blackhawk drives? Where is the web site? Thanks
Old 03-12-2004 | 08:41 AM
Blackhawk is made by Merc
Old 03-12-2004 | 08:50 AM
Blackhawk -no longer made by Mercury
Fast Shafts is offline
Old 03-12-2004 | 11:35 AM
Blackhawk, good drive?
Old 03-12-2004 | 01:45 PM
38KV's Avatar
Blackhawk is a duo prop surface drive made by Mercury for a few years, I think 1995-98.It will fit the Bravo bellhousing,and what I have heard worked best on cats.
38KV is offline
