Superchaeger? >
Superchaeger?
Superchaeger?
Old 03-15-2004 | 12:59 PM
KCHOTBOAT's Avatar
Charter Member #737
When I have a blower in my HTM I had to upgrade the fuel lines all to 1/2 inch. A HV mechanical pump should work fine with a blower that size. The jetting sounds low I would have nickerson prep the carb.
KCHOTBOAT is offline
Old 03-15-2004 | 02:32 PM
FWK
My first thought is to small of fuel lines and change the distributor
Old 03-16-2004 | 12:55 PM
BlownBajaOnHavasu
jets sound small. i run 90's in all four corners of dual 650's on a 468 with an 871 supercharger, and i run manifold referenced power valves.
blown engines starve for fuel going through mid-range, and can go lean. fuel line sounds too small also, i run 1/2" from tank to carbs.
Old 03-21-2004 | 10:00 PM
topfuel's Avatar
Originally posted by Hot Boat
Last season a friend of mine had his fuel tanks changed. when he got the boat back it wouldnt go past 4500 rpm and was running leal. What he found was that his pickup tubes in the tank were to small and starving the engine for fuel.
In my opinion a 3/8 fuel line is kind of small for a blower motor of that size and hp
The fuel tank is where I would look first. I had a 27' Mach 1 with a 454 and a 250 B&M on oval port heads with a Holley high volume/high pressure mechanical pump and a blue regulator set at 7lbs. That combination would pull strong to 6200. The line running to the pump was 1/2".
topfuel is offline
Old 03-21-2004 | 10:02 PM
topfuel's Avatar
www.topfuelperformance.com
topfuel is offline
