Prefered Spark Plugs? >
Old 03-14-2004 | 01:18 PM
MrCIG's Avatar
Charter Member#330
Default Prefered Spark Plugs?
Just wondering what everyone prefers as far as spark plugs go.
Please note if they are N/A motors or Blown to help keep things straight.
Mark
MrCIG is offline
Old 03-14-2004 | 02:04 PM
Biggus's Avatar
NGK 5673-8 in a blown application.
NGK BR6FS in the little Pachanga
Biggus is offline
Old 03-14-2004 | 02:18 PM
38KV's Avatar
AC Delco MR41T in N/A
38KV is offline
Old 03-14-2004 | 02:48 PM
obnoxus's Avatar
Charter Member #1171
I have been running A/C Rapid Fires in the Baja for years. I have had good luck with them. They are part #1
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 03-14-2004 | 03:08 PM
Crazyhorse's Avatar
Mine had the NGK 5673-8 plugs in it when I bought it but they were a bit cold for the way i run. I switched to NGK UR5 plugs but I don't run the boat hard. By the way, we dyno'd the first engine with the UR5's and it made 681@5600 with 7 lbs. boost.
Mark, are you interested in trying my Thunderbolts with the V-6 modules? I'll even deliver them if you and Patti can take a break and go to the Oven Grinder for dinner.
Crazyhorse is offline
Old 03-14-2004 | 06:42 PM
homan
NGK V7 N/A 502
Old 03-14-2004 | 11:07 PM
NGK UR5's in my 525SC. They are the same heat range as an AC 41.
I had good luck with the Rapid Fire #1's in an n/a 454. Same heat range as an AC 43. They just don't make them cool enough for the 525SC.
Griff is offline
Old 03-14-2004 | 11:35 PM
What about Bosch plugs?
Active Mike is offline
Old 03-15-2004 | 02:38 PM
MrCIG's Avatar
Charter Member#330
Thanks Guys, Just wanted to see what everyine was using I've used AC and Ngk's
Dave, The numbers look good on the dyno.!!!!
I got my motor back and it's ready to go back in the boat.
Just need to touch up some paint and polish the valve covers and intake.
I would like to try the V6 modules. I won't need them til summer.
Are you coming in for the COPs party on the 3rd?
Mark
MrCIG is offline
Old 03-15-2004 | 04:13 PM
cstraub69@comcast
Denso Irridiums. . .Expensive at $12 each but they are the best. BTW, Denso makes NGK's.
Chris
Stef's Performance
