prop selection 2550 sx >
Old 03-16-2004 | 08:55 PM
dragraceguy
Default prop selection 2550 sx
I am restoring a 91 Chaparral 2550 sx. the boat had 250 orig hours equipped with the 330/454/ bravo. Reading the posts i decided to do the top end and replace the heads with 71 vette heads. The compression should be about 9.2 to one. The ports are 262. I installed a crane marine cam with 529 lift. added crane gold rockers and 3/8" push rods. The motor looked almost new in the holes. Being fresh water cooled , i decided to use the performer rpm intake and a 770 holley street avenger setup for marine use. The boat weighs about 4400 lbs. it spins a 19' quicksilver prop. can I go to a 23" pitch?
Old 03-17-2004 | 01:20 AM
BADINTN
I had a '88 2550 with the same motor that I bought with a 19" mirage prop. I installed a Crane Commander cam with .536"-.553" lift, large ovalport GM heads with 1.88"and 2.19" valves, Edelbrock Performer RPM intake, a Holley 750 DP and Stainless Marine exhaust. I ended up spinning a 23" mirage that was tweaked to about a 22.5" pitch at 4900-5000rpm. I spun an untouched 21" mirage at 5200 rpm. Over all I went from 58mph to 65mph.
Old 03-17-2004 | 12:00 PM
HOUSTONPROP's Avatar
Default Mirage ACCLERATOR
in a 23 ACCLERATOR design would work great ,Might have to work it down in pitch but that would be a great starting point.
HOUSTONPROP is offline
Old 03-17-2004 | 12:52 PM
throttleup's Avatar
Dragraceguy,
What is your WOT RPM with the Quicksilver 19P and what is the speed at WOT.
Julie
throttleup is offline
Old 03-17-2004 | 02:59 PM
Default ACCLERATOR
We can send you one to try out if you want.
One call does it all.
Courtholl
Pantera
8
03-31-2007 10:13 AM
speedboatr
Prop Talk
3
08-31-2006 06:22 AM
RACER8
Skater
2
07-21-2004 03:31 PM
RACER8
1
07-19-2004 11:37 AM
wwwTOPDJcom
03-12-2003 12:47 PM
