-   -   Bazooka Tubes (https://www.offshoreonly.com/forums/general-q/74301-bazooka-tubes.html)
aTX427 03-16-2004 10:48 PM
Bazooka Tubes
Is anyone using the marine self amplified units? Thinking about mounting two 10" 150w units on the first bulkhead under the deck of my 25 Daytona.
Tricky919 03-16-2004 11:34 PM
I used a non amplified Bazooka tube my boat and it worked and sounded great............
BlownBajaOnHavasu 03-17-2004 09:30 AM
the self-amplified bazooka tubes leave a lot to be desired. i would use bazooka tubes, but with a separate amp. place them so they fire into a solid surface, they sound better.
97BossHammer 03-17-2004 09:52 AM
I agree with BlownBaja....buy the regular tubes then buy your own amp. You'll have more power. I like the Bazooka's, they sound real good and don't take up a lot of space.
fund razor 03-17-2004 10:06 AM
I use the non-powered with separate amp. I like the non-powered dual voice coil model. If you can mount it a few feet from a solid surface like a bulkhead, it will work the best. I bought an amp with good low pass adjustments, so I had more control over what freqs were going to the bazooka and it works really good.
It's really effecient too, so you don't need gobs of power.
