$%&#@ Compression fitting.. >
Old 03-17-2004 | 03:27 PM
Cignificant's Avatar
Default $%&#@ Compression fitting..
Getting my Cafe' back together has come to a screeching halt because of four little brass fittings. The hydraulic lines from the trim pump go into a "connector"
(part 33 at http://www.mercruiserparts.com/Show_...GIMBAL+HOUSING) that bolts to the bottom of the gimbal housing. The connectors on the ends of my lines won't screw directly into the connector - they go though a brass fitting. All four of my fittings were so corroded that they fell apart when I started reattching the lines.
So now I'm looking for these fittings. As much as I can determine they are called "double compression" fittings, and the ones I need are 3/16"F x 1/4"M. They are part #12BB on this web page (I think). http://www.couplingsco.com/page7.htm
Does anyone know where I can get four of them?
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 03-17-2004 | 03:46 PM
I think what you're looking for is an inverted flair to NPT fitting. Check an auto parts store that has a selection of brake line fittings.
Gary
Gary Anderson is offline
Old 03-17-2004 | 04:13 PM
Ed
Default What You Need...
Is Mercury Part # 22-77366...Order four of them from your local Merc Dealer. Or...Go to your local AeroQuip dealer with your hydraulic junction block & tell them what you need. The AeroQuip dealers are familiar with "power-trim lines". They should have this fitting in brass from either AeroQuip, Parker, Weatherhead, or Brasscraft. I don't think this would be called a compression fitting. This would be called a male inverted flare to female inverted flare "adapter"... Hope this helps. Ed
Ed is offline
Old 03-17-2004 | 04:29 PM
Mbam's Avatar
Offshoreonly Advertiser
Steve, I don't understand what has corroded. Do you mean the brass fitting that connects the hose to the connector block?
The connector block is originally made with either a #3 or #4 inverted flare female thread depending on the drive and boat age. Am I correct that you have the braided style lines that were made up by Cigarette? If so they are #3, and I am guessing that you have Bravo's which use a #4 connector block. If all this is true you need a #3 female to #4 male inverted flare adapter, and you will find it at your local hydraulic supply house or possibly a well stocked auto parts store. We have them but I know we pay way to much for them. I think they are made by Weatherhead or Parker. Forget all of what I said and listen to Gary & Ed if someone has drilled and tapped your connector blocks.
Mbam is offline
Old 03-17-2004 | 04:31 PM
birdog's Avatar
NAPA........Bet they have what you need
birdog is offline
Old 03-17-2004 | 04:45 PM
Official OSO boat whore
Napa won't have these little fittings. They are something special. Be forewarned. There are two different sizes.
Cord is offline
Old 03-17-2004 | 04:54 PM
You all rock!
Mercruiserparts.com, here I come!
Steve Gresham
'03 Donzi 33ZX
Old 03-17-2004 | 04:56 PM
Napa didn't have them, and neither did Lowes, Home Depot, an industrial supply house, a plumbing supply house, an HVAC supply house, or the Mercruiser dealer where I buy parts (In fact, he told me I had the wrong lines).
Steve Gresham
'03 Donzi 33ZX
Old 03-17-2004 | 07:26 PM
Mbam's Avatar
Steve, is it the #3/4 adapter you need? Post a picture to be sure. We do have them, call me at 954 545 8681
Mbam is offline
Old 07-27-2005 | 08:23 PM
bn
Default Re: $%&#@ Compression fitting..
Did you ever locate this fitting? I have the same male/female connector between my pump and braided trim hose and it has a slight leak.
Wondering where I can get this fitting from?
bn is offline
