side vs low water pickup speed diff? >
Old 03-18-2004 | 09:07 AM
INDY27's Avatar
Default side vs low water pickup speed diff?
anybody have experience with running a bravo with side water pickups vs the low water pickups on a 85 mph+ v bottom? I have heard the the low water pickup will rob 1-2 mph!
AUTOCONNECTIONLLC.COM
INDY27 is offline
Old 03-18-2004 | 12:17 PM
I tested the theory last year.
I ran the boat wtih the low waters,
got noted max GPS speed.
Then hauled out boat, swapped drives
to side p/u, ran again ( about an hour and a half
later, identical conditons) ran boat, note
max GPS speed.
The side water p/u's were 1.4 mph faster.
This was in the low 80 mph range.
jt
JaayTeee is offline
Old 03-18-2004 | 12:40 PM
INDY27's Avatar
thanks for the info, I was considering buying a brand new bravo with the low water pickup but am having second thoughts now. I have spent way too much money trying to faster and sure dont want to spend more money to go slower!
INDY27 is offline
Old 03-19-2004 | 10:02 AM
hotlavey's Avatar
jt
Any change in the engine water temp when you went to the side p/u?
hotlavey is offline
Old 03-19-2004 | 10:36 AM
No difference noted.
jt
JaayTeee is offline
Old 03-19-2004 | 07:57 PM
I suspect that water pressure may be a factor in the speed. In theory anyway, the increase in water flowing through the engine may be restricting the exhaust?
BadDog is offline
Old 03-20-2004 | 11:50 AM
INDY27's Avatar
the answer I got was that the water inlet holes are so big that they disrupt the flow of water to the prop.
INDY27 is offline
lennyk
07-15-2008 07:19 PM
GregP
4
06-13-2007 03:50 PM
SSComp
1
12-25-2005 10:40 AM
kilroy
07-21-2004 08:34 AM
kilroy
2
07-19-2004 02:00 PM
