Removing silent choice block off plate #? >
Old 03-18-2004 | 02:35 PM
dyno's Avatar
Charter Member #655
Default Removing silent choice block off plate #?
anyone know the merc part # for the block off plate? the choice has to go!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 03-18-2004 | 02:41 PM
cougarman's Avatar
Default No But............
It's quite simple to make your own too.
The plate is probably 2" X 3"
Pull you silent choice off trace your shape of
your mounting flange along with drilling the
4 holes into a piece of 1/8 plate.
And mount it. When you pull the (Y) pipe
it has an O-ring, but I still add a little silicon
for flavor. Can't get to it once you engines
are back in.
Good Luck! If you have access to some
stainless 1/8 plate you'll have no corrosion.
Had good luck
Here
Cougarman
cougarman is offline
Old 03-18-2004 | 02:43 PM
Doller Offshore
the bravo block off plate #861776a2,comes with
hardware.
Old 03-18-2004 | 10:51 PM
FunHome's Avatar
Can you remove Silent Choice while the motors are still in the boat?? Or do they have to be pulled???
FunHome is offline
Old 03-18-2004 | 11:04 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Motors at least have to be moved forward to gain access to the bullhorn bolts.
US1 Fountain is offline
Old 03-19-2004 | 04:54 AM
The bolts that Merc supplies with the kit for the plate have extra thick washers. You can buy the bolt kit separate.
BadDog is offline
Old 03-19-2004 | 07:01 AM
Bill 3's Avatar
Let me look, I may have a blockoff plate laying around that you can have.
Bill 3 is offline
Old 03-19-2004 | 08:03 AM
dyno's Avatar
Charter Member #655
Thanks man!! then I can use it for a template to make one more!!!
dyno is offline
Old 03-19-2004 | 08:09 AM
tssteph's Avatar
If you are not concerned about weight why does the Y pipe have to be removed? I have seen several boats with caps on the tops of the Y pipes with a stainless clamp. It sure seems easier then pulling motors. Just a thought.
tssteph is offline
Old 03-19-2004 | 12:01 PM
Bill 3's Avatar
i totally forgot to look when I was at the shop today, I will have to look on monday. Although I am sure I have one. email or PM me your address and I will ship it monday.
Bill 3 is offline
