Crane Hi6M ignition >
Crane Hi6M ignition
Crane Hi6M ignition
Old 03-11-2002 | 08:18 PM
  #31
KAAMA's Avatar
US1, I wasn't their when he tried my Crane box system. I'll have to ask him. I know that when we dyno'd MY engines (the 540's)we could get the idle down to 500rpm with a 70 pound brake load from the dyno. This simulated the engine as if we were idling through the channels, piers and "NO WAKE" zones. With my engine we didn't run it any other way because I already owned the Crane ignition system anyway. I should also note that I run the MSD crank trigger system on my engines with a MSD Billet distributor. That crank trigger doesn't EVER MOVE...the timing is ALWAYS right on whenever we check it! Tom Earhart (dyno owner/operator and marine engine guru) really likes the Crane system. He even uses one on his engine in his snowmobile!
He's in the engineering field and has something to do with designing and testing fuel injection systems for all kinds of crazy stuff...including train diesel locomotives. I hope I'm accurate in remembering this, but Tom was telling us how a locomotive these days has twelve pistons that are about 12-14 inches in diameter which are about 700 cubic inches each...that's EACH PISTON! These train engines make about 4000hp @1100rpm...the torque was the most impressive and for some reason I CANNOT remember what the figure is....dang! It's several thousand for sure....it's way over and above the horsepower figure of 4000 though!
KAAMA is offline
Old 03-11-2002 | 09:00 PM
  #32
US1 Fountain's Avatar
Ginger or Mary Ann?
So if I have to keep my idle at 1000 rpm to stay running in gear, (possibly a touch rich), these ignitions will really help because of the hotter, multi spark? Idle quality is what I'm really looking for.
US1 Fountain is offline
Old 03-11-2002 | 10:23 PM
  #33
Just put a pair for sale at a good price in the major component section.
Todd H
Todd Hartigh is offline
Old 03-12-2002 | 07:59 AM
  #34
KAAMA's Avatar
US1, yes it should really help the idle quality of the engine, especially when you have to manuver around docks, boat traffic, water currents and wind. It's a bad thing when you encounter these things and your engine(s) keeps dying from loading up, etc. With the Crane ignition you'll benefit from the mulitspark it gives at low rpm.
Hi Todd!
KAAMA is offline
Old 03-12-2002 | 10:18 AM
  #35
How are ya? is the boat coming along?
Good Luck with it!
Todd
Old 03-13-2002 | 12:55 AM
  #36
Nabber
"These train engines make about 4000hp @1100rpm"
Wow, that's over 19,000 ft-lbs of torque.
Old 06-23-2005 | 11:36 AM
  #37
Default Re: Crane Hi6M ignition
Originally Posted by IRONMAN
One more question will my stock tach still work? And thanks to all who responded I have decided to use the Crane over the jacobs or msd. The Ironman.
Iron Man-
I am also using the Stock Merc HET distributor, removing the Thunderbolt box, and adding the Crane HI-6M.
Is the performance better?
How did th etach hook up?
Did you need the tach adapter?
tpatwil is offline
Old 06-23-2005 | 12:43 PM
  #38
Try carshopinc.com
They have it for $294.95 They've pretty much beat any price I've got anywhere else. I've also called and spoke with Tim (1-800-603-4359), always very helpful.
http://crane.carshopinc.com/product_...6290/6000-6462
Liberator21 is offline
Old 06-23-2005 | 01:16 PM
  #39
Stormrider's Avatar
JC Performance Engines
I've got it on my 454 making 560hp 550lb.
It helps w/ timing and gives a nice rev limiter.
Stormrider is offline
Old 06-23-2005 | 06:51 PM
  #40
KAAMA's Avatar
This thread certainly goes back a few years! By the way, I still have the same Crane Hi-6M Marine ignition boxes, and PS-92 coils that I originally had and they still work fine. I purchased them about 5 years ago. One was even drenched with high pressure water.
KAAMA is offline
alecsammy
5
10-21-2008 07:32 AM
fastlane40
08-09-2008 01:33 PM
Blue by You
17
05-11-2006 04:45 PM
BadDog
3
04-15-2002 02:39 PM
BadDog
1
03-26-2002 09:40 PM
