-   -   Re-setting hour meter? (https://www.offshoreonly.com/forums/general-q/7486-re-setting-hour-meter.html)
Raypanic 02-02-2002 02:33 PM
Is there a way to reset a mechanical hour meeter? I repowered and would like to start at -0- again. I know I could buy a new one but would like to save a few bucks. - Ray
hotbeek 02-02-2002 02:38 PM
That would be a bad thing ! There'd be a lot of people turning them back. Just note hours some where.
Put some juice to it and stop it when it turns to zero. :D
Goodfella 02-03-2002 09:27 AM
A mechanical hour meter? What does it hook up to to check for running time? :confused:
CigDaze 02-04-2002 07:40 AM
Is it mechanical, meaning analog and not digital. I think that it will turn hours anytime the key is in the run position.
Like hotbeek said You can just give it the the proper voltage(probably 12, but check manual) and it will turn. :D :D :D
I don't know about yours, but my gaffirg will take an awfully long time to return to zero. :D ;) :D :D
[ 02-04-2002: Message edited by: Baja Daze ]
Dredgeking 02-04-2002 08:05 AM
i think you'd have to take it apart like turning back the odometer in a car. they aren't meant to be zeroed out.
Griff 02-04-2002 04:37 PM
If you've got 510hrs now, hook it up to power for 490hrs and it'll be back to zero. 490hrs= 20 days+
boot 02-05-2002 10:25 PM
NO they can't be reset .What I like to do is leave it there so you know how many hours are on the boat and get new ones by the motors to keep track of the new engines . Good selling point too . UNless you have 1000 hours already then just through it away ! :D
