Merc T-bolt Ign System..what do I need? >
Old 03-24-2004 | 07:47 AM
Thanks for the responses..
Are there differences in the IV, V, distributor? Differences between EFI and Carb motors?
Shah Mat is offline
Old 03-24-2004 | 08:16 AM
If your 502 has a roller cam you may need to change the distributor gear to work with that cam.
As far a the differeces you ask about, Sorry, I don't know. But some one here should be able to answer that for you.
Kidnova is offline
Old 03-24-2004 | 12:26 PM
Sha Mat,
Save your self a lot of agravation! OK, there is nothing wrong with the Merc setup, but for $315 you could have a new DUI complete ignition system distributor and all! There are only two wires to hook up, igniton(purple) and the tach (gray). I have been running mine for three years now with no problems. You just tell them what you want for advance curve, and you have it at your house in a few days! Just go to: www.performancedistributors.com
If you have an HP500 cam, I would suggest 20 degrees in the distributor with it all in by 3500rpm. You really should find out exactly what you have for a cam to set the ignition properly.
Make sure you know which gear to run with your cam!
TomR is offline
Old 03-24-2004 | 01:32 PM
z.zuperboat, Your pm box if full. I will e-mail you later.
Thanks,
Joey
Shah Mat is offline
RunninHotRacing163.1
Wanted
5
01-25-2023 07:06 PM
Big Block Billy
1
07-13-2007 10:07 AM
Rage
12
04-26-2006 02:31 PM
ratman
1
01-06-2006 12:29 PM
glassdave
5
06-14-2002 08:30 AM
