Originally posted by 38KV Looks like a 3.8 or 4.2 litre Jaguar. |
Here is what a 3.8 liter Jag motor looks like...
bildge
97bosshammer,
I use 1 can of disk brake cleaner,let it set 10 min. the flush with water , works for me. |
I used a regular degreaser and a bunch of water. The motors are out so it was wide open. I thought that the idea of filling th bilge with hot, soapy water then drive around the block was a good idea. So, I filled 'er up hooked the truck up and drove to the car wash.
The bilge is squeaky clean and all of the oily water ran right up into the cabin:rolleyes: What a dummy... |
I've used Super Clean and a couple of buddies of mine discovered "Purple Power" found at your local Advance Auto to be a spray on; set for a bit; spray off product.
BUT whatever you use, after it has dried out a bit go back in and spray everything down with WD-40 to preserve the surface of all metal areas and help prevent those spots mentioned above. As another cleaning tip from your local Advance Auto store: Mequires Tire/Rim cleaner that comes in a clear spray bottle of pinkish liquid. Cheap; effective; easy to use yellow hull cleaner. Just spray on, let sit a couple of minutes and spray off. It doesn't have to necessarily have to say Marine boyz... |
Originally posted by Reed Jensen Close .... but no cigar... Jags have iron blocks and aluminum heads... this engine has an alloy block... but it is English.... I'll give you a bigger hint... like Jaguar... this company is also owned by Ford Motor Company..:D |
Originally posted by robyw1 I ran Palmolive on the lake so the sloshing effect would clean better. Problem is that I had bubbles coming out the bilge blower. :D:D It cleaned it though Roby That funny:D |
Originally posted by magnum27 I am going to say Austin Martin, possibly out of a DB7. The Jag photo is sweet. The XKE is one of my favorite cars. I just love British and American sports cars. Do you have any picks of a Lotus maybe? |
| All times are GMT -5. The time now is 10:35 AM. |
