Carb Choice
Old 03-25-2004 | 11:57 PM
SpeedJunkie's Avatar
Question Carb Choice
I just purchased a 1993 32' Envision it has 2 454's that have been built. to what extent i don't really know. The last owner told me thaey were 500 bhp each. At the moment it has holley 650 dual feed double pumpers with mechanical secondaries. Right now it likes to stumble when you give it full throttle from off idle. I was wanting to change carbs but to what I have no idea. Any Suggestions???
SpeedJunkie is offline
Old 03-26-2004 | 02:59 AM
Reed Jensen's Avatar
Sounds like you need vacuum secondaries... or bigger jets for the accelerator pumps.
Reed Jensen is offline
Old 03-26-2004 | 03:55 AM
I wouldn't worry about the carbs. If you keep doing that you'll be needing drives.
Griff is offline
Old 03-26-2004 | 11:25 AM
dlbCheckmate's Avatar
You need to play with the accelorator pump cams and taylor the pump shot. This could involve new squirters as well. I had a simular issue with my 468, I changed out to an 830 cfm (from 930).. My 2 cents
dlbCheckmate is offline
Old 03-26-2004 | 03:24 PM
aero-offshore's Avatar
What Griff says, or If your not carb litterate, like me, you send them along with your motor specs. to www.pro-system.com Belive me it's the best money you'll put in your boat!!!
aero-offshore is offline
Old 03-26-2004 | 03:43 PM
mopower's Avatar
Toxic FORMULA
I second what Griff said Believe it especially if you straighten out the carbs .
mopower is offline
Old 03-26-2004 | 08:49 PM
'05 Concept SF23
Call Dean Nickerson in Bristol, PA. He is a great marine carb man.
f311fr1 is offline
Old 03-27-2004 | 07:54 AM
blue thunder's Avatar
I wouldn't waste the jingle on those carbs. Buy some 800cfm holley carbs. That is what merc put on all mild performance engines like the hp 500, 420 etc. 650cfm is theoritically size properly, but in practice will be restrictive in my opinion.
BT
blue thunder is offline
tssteph
Wanted
2
07-31-2008 08:14 AM
fulloblarney
3
02-15-2005 04:31 PM
Donzi Black Widow
14
06-23-2004 10:53 AM
Kokopelli
15
09-16-2003 10:07 PM
meander77
15
06-24-2002 09:57 AM
