took out the krytonite for the first time. >
Old 03-28-2004 | 07:04 AM
sleeker
Default took out the krytonite for the first time.
2001 krypto 29 with a pro charged hp 500 carbed.just bought it in january with the motor just off the dyno (redone) and a new brovo 1 with 1.5 ratio.imco gears/shafts lwp e.c.t.the original bravo had blown and had 1.36. and i only was given the orginal bravo 30p that was good for the 1.36 ratio the prop you can tell has been repaired a few times also.we new the old prop with the new gearing would be wrong i was also was given a credit that the owner had with throttle up for the new prop they said try what you got first and let us know.so 3/4 tank fuel 4 people weighing arond 950 total.and and soon as you get in it and into it hammer down and into boost its at the rev limiter 5200/5300 only need about 5/8 of the throttle down to not be into the limiter and its reading 83mph on the gps.also im really going to need to jet it down 92 jets are in front and drilled jets in back so not sure of size no stamped # on them. ill have to try some numbered drill bits in them to find the size and go from there. plugs are dry but black as charcoal electrode and all and transom has alot of soot.after talking to jullie a while ago im going to try a hydromotive Qiv any ideas on pitch.i know hydros are different than brovos and the same # hydro lowers your rpm some.i dont even think a 32 bravo would be tall enough the way its gettin into the limiter like nothing if that helps some.i actually have a couple of inches of throttle left and im at 5200 and thats with some big boys on the boat almost 1000lbs and way rich.this thing feels like it should have a good 15+mph in it.also not sure where the sweet spot is on the mech trim indicator the last owner said he thought around 5 (but like everthing else i was told WRONG) it was only 78mph at 5 i went to 6.5 and it went 83 i didnt try it any higher.im pretty siked overall a just need a little prop tuning and jetting and best of all it drove out and BACK IN.im gonna call jullie at throttle up tommorow to order the prop but cant give great info with it so hard into the limiter any ideas on the hydromotive qiv pitch?.THANKS SEAN
Old 03-28-2004 | 07:08 AM
eyezlee's Avatar
sounds like a nice ride. Suggestion on your post. Put some line breaks in there. Its damn hard to read and get all the info.
eyezlee is offline
TYPHOON
OPA/The Jersey Boyz
8
07-29-2008 05:20 PM
HayJay
06-01-2006 07:00 PM
TeamRelentless
General Racing Discussion
2
03-08-2004 03:41 PM
