DPX Steering Helm >
DPX Steering Helm
DPX Steering Helm
Old 03-29-2004 | 08:12 AM
Default DPX Steering Helm
Hello
I have a Dpx drive whitout steering helm is anyone know how big in cc i need to be its very expensive to buy it from Volvo penta so i need all tips
Regards
Mattias Sweden
mattis75 is offline
Old 03-31-2004 | 03:07 PM
ForrestC's Avatar
Good question. I have a pair of DPX-A drives ready to go in my Magnum 27, but like you, I don't have a hydraulic helm unit yet. Volvo-Penta wants about $750 for a new helm-unit for twins and close to that amount for the same unit for a single.
Anyone?
ForrestC is offline
Old 04-01-2004 | 09:12 PM
Allan4
Hi guys,
If you are refering to the hydrualic helm unit that mounts under the dash for full hydrualic steering systems I can sell you non-adjustable 145cc helm units for $379 each, considering it will work on your DPX system. I do need to double check.
Just throwing that out there for you.
PM me if interested.
Allan
Old 04-02-2004 | 10:28 AM
Allan4
The unit we carry will work with your system, assuming you are talking about the helm unit that mounts under the dash.
Hope that helps,
Old 04-02-2004 | 02:12 PM
ForrestC's Avatar
Allan that's great . . . and yes, it's the unit that mounts behind the dash. I know that there are two different helm units available from Volvo-Penta: One for a single DPX outdrive (two steering rams) installation and another for a twin DPX outdrive (four steering rams) installation. I'm sure that most any five-port Char-Lynn type unit will work, I just want to be sure to get the unit with the correct size unit so as not to make the steering too quick or too slow.
ForrestC is offline
Old 04-02-2004 | 04:13 PM
ForrestC's Avatar
[i] . . . I'm sure that most any five-port Char-Lynn type unit will work . . . [/B]
Should have typed "four-port".
http://volvopentaparts.stemtostern.c...=71124#diagram
Forrest
I guess I should contribute a few bucks to OSO so that I can at least edit my typos!!!
ForrestC is offline
Old 04-02-2004 | 04:28 PM
Allan4
You are correct Forrest, that would be a 4 port.
You would be best served using a 160cc flow rate unit. I can sell you those at the same price as above.
I hope this helps you out.
Allan
Old 04-03-2004 | 03:56 AM
Question
Is 145cc ok for singel instalation to??? or shall i have a smaller?
mattis75 is offline
Old 04-03-2004 | 05:08 AM
Half Nutz's Avatar
test
Half Nutz is offline
Old 04-03-2004 | 05:12 AM
Half Nutz's Avatar
one more
