Need Merc PN >
Need Merc PN
Need Merc PN
Old 03-30-2004 | 11:50 AM
Allan4
Default Need Merc PN
Hi folks, I need a hand here, if I may. I need the Merc Part number for a kit that lets you transform the drive trim from a CRT system to a throttle mounted system. I know Merc makes a kit for this, I just cannot find it.
It is for a Early 90's 42 Fountain with twins....
Thanks,
Allan
Old 03-30-2004 | 04:49 PM
marinetrans's Avatar
What is a CRT system?
marinetrans is offline
Old 03-30-2004 | 05:50 PM
Cordless Rotary Trim
509 SC is offline
Old 03-30-2004 | 05:51 PM
The trim buttons are mounted on the steering wheel
509 SC is offline
Old 03-30-2004 | 07:15 PM
Ok, I'll look it up tommorrow in my Merc book. So I take it its Merc HP controls. If they are need to know if the handles have fwd. or aft cant, and the color (black or white). Am I on the right page here?
Old 03-30-2004 | 08:53 PM
Allan4
Yes, I think so. I do not have the answers for you, sorry. It is a standard 4 stick setup. I have not seen it in person, I am trying to help out a steering system customer of mine. I will get the answers for you by tomorrow.
Thank you very much for the help, I'll check back tomorrow.
Old 03-30-2004 | 09:25 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Allan, I did somewhat the same thing on my last Fountain. It had the CRT buttons control the drive, But I wanted a throttle trim for the tabs cause I hated reaching for the dash everytime. You can use either drive or tabs, just have to tap into the appropiate wires.I ordered the parts from BAM for right at $100. This was to install the switch in the Kiekxxx shifters. Since you are going to control twins drives with a single switch,(I assume?) you will need to order 2 diodes. This way the throttle switch will operate both drives at same time, and also will allow for separate trimimg from the dash switches.
Is this what you are trying to accomplish?
I'm using the throttle switches for tabs, crt for drive.......
US1 Fountain is offline
Old 03-30-2004 | 09:27 PM
Ginger or Mary Ann?
back side
Old 03-30-2004 | 09:39 PM
Ginger or Mary Ann?
trim switch parts
My throttle had the hollow handle, so I just used it and made the wire tube myself vs. the $$$$ for one with the tube welded to the front edge for the wires.
pt#'s needed for modifying Mercs throttles .......2,3,4,5,6, both #9's.
Might be alot easier to just buy the clamp on mounted switch. I fyou install one with 2 switches, then no need for diodes. But if using the single switch controlling 2 items, then 2 set s of diodes.
Old 03-31-2004 | 10:01 AM
Allan4
Great info. Yes, that is what we are trying to do. Go from a CRT to drive trim on the throttles. I was told there was a kit for this.
I think I have the info I need to figure this all out now. Thanks a ton. What you have done is the same thing I am looking to help him do, just with the drive as opposed to the tabs.
Thanks for all your help guys, I appreciate it.
shw-n-go h20
8
07-29-2008 10:05 AM
Magic34
10-24-2007 05:05 PM
dfealy
11
09-21-2007 04:07 AM
superwrench0166
1
01-06-2007 08:59 AM
timucin
4
11-03-2002 07:29 PM
