-   -   Merc 454 MPI dead in water (https://www.offshoreonly.com/forums/general-q/75547-merc-454-mpi-dead-water.html)
Reddog 04-02-2004 01:30 PM
Originally posted by GuyFM
...It turned out to be the 90amp fuse on the starter! I'm not sure if my buddy's neck will be the same after the headstand he did to get it off....
At least its you buddy's neck instead of your own. I blew the same fuse last month - operator error:rolleyes:
BadDog 04-02-2004 02:01 PM
You need to find out why the fuse blew. It will surely do it again unless you find the fault and fix it.
thomas1369 04-02-2004 02:30 PM
I also had this happen. It is my understanding, per MarineMax, that these fuses just blow every 5 years or so. You have the option to replace or just bypass the fuse all together. I replaced it just to be safe. And yes, you need to be an acrobat to change it!
blue thunder 04-02-2004 05:05 PM
Originally posted by NetGain
Also, does anyone ever have any issues with this engine and the Bravo One with the pickup on the front of the bulb? I have had problems with sucking mud into the cooling system in shallow areas and clogging.
Other than, don't turn your engine on in less than 3 ft of water, I haven't really gotten any good feedback for a fix.
People epoxy off the low water pickups and drill holes into the water passage at the traditional location. Do a search on that topic and you should get good info.
BT :cool:
NetGain 04-08-2004 11:28 AM
Blue Thunder,
Thanks for the feedback. This is the first decent idea I have heard.
The next best idea was to put a pickup in the hull or at the bottom of the transom with a switch inside.
I will check this out. Where are you on the Bay?
Thanks,
NetGain
blue thunder 04-09-2004 06:20 PM
Northern bay area netgain. I boat out of a marina that gets ass low at low tide and I have never had a problem with what is sucked into the standard bravo pickups. A freind of mine in the same marina had big problems with sucking up stuck, epoxied off the low water pickup as I said, and no more trouble.
BT
