where can i get a pulley
i need a pulley for my 79 454 -- it the crankshaft pulley and its a 2 piece setup (one is a 2 v-groove pulley -- with an insert for a 1 groove pulley)
anyone have any ideas?? |
Is the outer pulley smaler. It is 3 groove right?
Merc p/n 70081-c ($78 BAM) is an aluminum replacement. I do this all the time. The center groove on it is smaller though making necessary belt and possibly a seawater pump pulley change (if you have one). How about a billet one for apx $60 one ebay. All 3 grooves are the same, BBC short water pump . Look it up under automotive parts. I should have the steel pulley(s) but , must clean them to see if they are rotted or not. Let me know what happened. BBB |
yeah the outer pulley is smaller -- its the one that goes to the power steering -- its on its own pulley that is inserted into the main crankshaft pulley
thanks -- i'll check out BAM! |
this is what my pulley looks like -- is it normal to have the outer pulley smaller (it drives the power steering pump).
1 Attachment(s)
Most of the ones I've seen look like this...
1 Attachment(s)
