surface drive propeller ? >
Old 04-11-2004 | 05:04 PM
bck's Avatar
bck
Charter Member#568
Default surface drive propeller ?
This is a prop supposedly custom made for a 357 with Kaama drives. The only marking on it is; CT 524 0006 B. It measures 16 3/8 from tip to tip. I have a pair of them. How can I compare it to other props without knowing anything about it? How do I determine if its suitable for my application?
Straight bottoms and flat decks
bck is offline
Old 04-11-2004 | 05:07 PM
bck's Avatar
bck
Charter Member#568
bck is offline
Old 04-11-2004 | 06:06 PM
cuda's Avatar
They look like the same one's that are on my Kaama. As I recall, they measured 16 inches too. I think they were 26 pitch, not sure. I'd run out and check for you, but it's pouring rain right now.
If they don't work out for you, I might be interested in buying them from you.
cuda is offline
Old 04-11-2004 | 06:46 PM
bck's Avatar
bck
Charter Member#568
How can I figure out what the pitch is on these. If they are truely custom (they don't appear to be mass produced) I guess there would be something done to these that was not available "off the shelf". How do I tell if these are anything special?
bck is offline
Old 04-11-2004 | 09:33 PM
Do they have 19 splines I think they also fit Merc small shaft speedmaster I have several sets of them all have the pitch post your gear ratio and horsepower and some one will get you in the ballpark on pitch good luck.
fstboater is offline
Old 04-11-2004 | 10:20 PM
cuda's Avatar
Fstboater, what is the diameter of the speedy props?
cuda is offline
Old 04-11-2004 | 10:46 PM
I have from 15 5/8 to 17.5 and have seen 18 In. I have a set of 16.5 X 26 labed choppers that worked very well before I went to bigger power.I have herd that the shaft is the same but I havent tried to swap them my self.
Old 04-12-2004 | 10:40 AM
joe900sc's Avatar
Default Need some 19 spline props.
If anyone has a pair L&R 16.5X26 4bbl 19 spline props I'd be willing to purchase or trade.
I have a mint pair of 16.5X31 3bbl 19 spline props.
My phone is 608-220-0983. Or you can PM me.
joe900sc is offline
Old 04-12-2004 | 10:44 AM
joe900sc's Avatar
Default More...
I also have a set of 16.5X29 3bbl available too...
Thanks again.
joe900sc is offline
Old 04-13-2004 | 06:18 AM
bck's Avatar
bck
Charter Member#568
How do I figure out what the pitch is on the ones I have? The guy that I got them from said they were custom made and worth alot. How do I know if that's true?
bck is offline
