World heads
Old 04-11-2004 | 09:54 PM
Default World heads
I need a quick lesson on runner lenghths. I have 330hp 454's with small penut ports. I have found a set of heads by world products that have a runner of 269 cc, 119 cc chambers 2.19 and 1.88 exhaust valves. Will I see any inprovment in perf by bolting these heads on along with Edelbrock 2.0 a cam shaft change and holley 750. Will the compression be too low? I can get the heads for $725
Andy is offline
Old 04-12-2004 | 04:55 AM
dyno's Avatar
Charter Member #655
Andy are they ovals or rectangulars? I think your going to want to swutch to a 9.5/1 compression piston. I bought a set of castings on the board for $350.
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 04-12-2004 | 06:37 AM
They are ovals When you say castings, do you mean heads with no valvetrain. If I need pistons to bump the compression I will get a set of Vortecs (heads) and do the easy hp untill next fall
Andy is offline
Old 04-12-2004 | 10:52 AM
cstraub69@comcast
That would be Worlds oval port. For your application, the right cam, you should see a gain of 70HP easily.
Chris
Old 04-12-2004 | 11:34 AM
dyno's Avatar
Charter Member #655
if your going to change the cam and heads you might as well do it all and bump the pistons too.....my.02
dyno is offline
teaguecustommarine
New Products and Member Discounts
2
01-10-2011 10:20 PM
ghittner
1
12-27-2007 10:09 AM
ghittner
1
06-19-2007 09:29 AM
ghittner
6
06-18-2006 10:02 PM
Dave1972
6
12-09-2003 02:16 PM
