Vibration at Speed >
Vibration at Speed
Vibration at Speed
Old 04-13-2004 | 02:20 PM
Default Vibration at Speed
I get a vibration when I put it in gear. It doesn' really get worse on plane or at speed. Oil pressure and temp are both good. RPM"s are good. Oil looks good.
Maybe just an outdrive/engine alignment? Any thoughts would be appreciated.
NetGain is offline
Old 04-13-2004 | 03:59 PM
38KV's Avatar
If you don't get any vibrations in neutral, it definitly is a outdrive/propeller issue.
Bad engine alignment don't usually cause vibrations.
Have you checked your propeller for damages?
38KV is offline
Old 04-14-2004 | 06:16 AM
throttleup's Avatar
Netgain,
I agree with 38KV. Check the prop. It's the easiest to check and most common problem of vibration. Inspect the prop for impact damage and bends in the blades.
Matt
throttleup is offline
Old 04-14-2004 | 06:52 AM
Thanks for the responses. I will let you know how I make out!
NetGain is offline
GNJ
6
07-13-2005 07:44 AM
boatfreak
2
06-27-2005 07:30 AM
krypto 1 in CT
2
04-25-2004 04:56 PM
Shah Mat
4
04-22-2003 03:37 PM
max
5
11-12-2002 08:24 AM
