Interesting OEM 522 Whippled EFI engine build. >
Old 04-14-2004 | 09:34 PM
Infomaniac's Avatar
Bearing clearance was a bit much on rods and mains.
Had to buy two sets of bearings. One standard set and one with .001" less clearance.
For example shooting for .003" clearance on the mains. It measured out at .0035"
To correct this I install a standard bearing half and a .001" tight bearing half in each hole. Brings the clearances right where I wanted them.
Now what to do with the two broken bearing sets?
Infomaniac is offline
Infomaniac's Avatar
Just a shot of the rings fit and waiting to be installed on the pistons.
Infomaniac's Avatar
What an oily mess. 2 more spiro locks - rings and in the holes they go.
Old 04-14-2004 | 09:35 PM
Infomaniac's Avatar
Oily workbench mess now in the engine. Perfect .005" in the hole as planned.
Infomaniac's Avatar
One Edelbrock Marine, Isky springed, titanium retainered, gasket matched head ready to install.
Old 04-14-2004 | 09:36 PM
Infomaniac's Avatar
Using custom thickness Cometic head gaskets.
Two outer layers are coated and standard thickness. Inner layer sets the overall thickness.
Infomaniac's Avatar
Check head gasket fit against the head.
Make sure everything lines up.
Infomaniac's Avatar
And check head gasket fit on the block.
Will install 1 head tomorrow.
Old 08-17-2004 | 09:08 PM
Default Re: Interesting OEM 522 Whippled EFI engine build.
Hey , Paul Harvey" , wheres the rest of the story !?!?
boot is offline
Old 08-17-2004 | 09:42 PM
Infomaniac's Avatar
Let me start copying and pasting. It will take a few minutes.
Can be found here as well as other build projects
