MercTrans II. Oil type? >
Old 04-15-2004 | 10:11 PM
Danny_Ocean
Default MercTrans II. Oil type?
Setup is TRS 454/330 w/MercTrans II. Dipstick says "ATF only", however the fluid on the dipstick isn't red like typical ATF. Not sure what the previous owner has in there. The oil looks clear with a gray tint, definitely not red.
I've read it takes Type "A" Suffix "A" or Ford Dextron, but does anyone know of a synthetic product that will work?
Thanks in advance,
D. Ocean
Pompano Beach, FLA
Old 04-16-2004 | 12:12 AM
spectra32's Avatar
Quoted from Mercruiser Service Manual #C-90-71707-880 (circa 1980)
"5. Use only automatic transission fluid (ATF) Type "A" Suffix "A" or Ford Dextron"
Capacity is 2 qts.
spectra32 is offline
Old 04-16-2004 | 12:28 AM
Danny_Ocean
Thanks. So would it be safe to assume that a synthetic ATF indicating "Type A" would be acceptable?
D. Ocean
Pompano Beach, FLA
Old 04-16-2004 | 06:20 AM
rws's Avatar
rws
I have had good results with B&M Trickshift Fluid.Although I only have a Wimpy Little Small Block in front of Mine.
Rob
rws is offline
Old 04-16-2004 | 06:42 AM
Audiofn's Avatar
Charter Member #232
I also use the B&M but it is called TRICK SHIFT. It definatly works well and has been recommended to me by guys running BIG hp through these tinny trannies.
Jon
Put your best foot forward!
Audiofn is offline
ak
29
08-16-2009 03:37 PM
Mackattack
09-27-2007 05:16 PM
NJgr8ful
5
04-16-2005 03:08 AM
THATS IT
4
11-02-2004 08:08 PM
impulsive
11-21-2003 06:43 PM
