Bravo I Question >
Bravo I Question
Bravo I Question
Old 04-19-2004 | 07:10 PM
Jerry B
Question Bravo I Question
I just bought this boat last fall. 29 foot Fountain / twin 502s. Everything seemed pretty sound. Just some minor things untill today I think. I was looking to drain and refill the lower units and cannot find the drain plug. I have a Seloc manuel that shows where it's supposed to be but not there. I see some sand scratches in the area where I think it's supposed to be on both drives but no sign of any plug. I know anything is possible but now I wonder if some idiot did some repair work right over the plugs. I hope I'm the idiot not looking in the correct place but I sure dont see it. The vent plug is in plane sight.
Jerry B is offline
Old 04-19-2004 | 07:23 PM
Elite Marine's Avatar
You did pull the prop and look in there by the shaft right?
Elite Marine is offline
Old 04-19-2004 | 07:32 PM
Jerry B
No. My last boat was a jet boat. This is all new to me. I did shine a light in by the prop hub but did not see anything but I thought the drain was on the front of the lowere unit just above the skeg. Is the plug behind the prop not visible untill prop is removed?
Thanks for helping a rookie!!!
Jerry B is offline
Old 04-19-2004 | 07:46 PM
formula31's Avatar
Yea, on many of the Bravos, the drain plug is in front of the prop. You have to take the prop off to see it.
formula31 is offline
Old 04-19-2004 | 10:31 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You have to fill the drives from the drain behind the prop with a gear lube pump, and not at the top vent screw or the drive reservoir. Use Mercs High Performance gear lube, not the Merc Premium gear lube.
US1 Fountain is offline
Old 04-20-2004 | 12:10 AM
As US1Fountain said you must fill the unit from the bottom plug which should be behind your prop. This is to prevent air pockets from forming in your unit when filling with oil.
Did you locate the plug?
Active Mike is offline
Old 04-20-2004 | 08:57 AM
Jerry B
I didnt have a socket to remove the prop at home last night. It's raining cats and dogs here in Kansas City right now so dont know if I'll get to do it tonight. I do understand the fill procedure. Just couldnt find the drain. like I said before, I cant imagine anyone would make repairs over the drain plug but my manuel says nothing about it being behind the prop. I'm a mechanic for a GM dealership and still after all these years they manage to leave out important info in service manuels. Of course it's all on the webb now.
Thanks for the help. I'm sure the plug will be behind the prop.
Jerry B is offline
Old 04-20-2004 | 11:03 AM
nixter's Avatar
Jerry,
Congrats on your new fountain 29 fever. Most
likely your Bravos are the newer style and like
everyone else has said, the drain plug is below
the prop shaft behind the prop. I use Royal Purple
synthetic. Never had a problem since using it
the past 4 years. I change it every 25hrs or when
i change my engine oil (Royal Purple also).
I also have a 1991 29 Fever with twin 454's that
are slightly masaged. I run 80-81 GPS with 26"
Hydromotives. Is yours a step or non step? Good
luck and have fun, Nixter.
nixter is offline
Old 04-20-2004 | 09:39 PM
Jerry B
1993. Not a step hull. Engines are stock 502 MPI.
Only ridden in it once at that was for the test ride prior to purchase. We brought it home last fall just to put it in storage. We have had a jet boat for the last 12 years, still do for now untill I sell it. This is a big step for my wife and I . Just a tad nervous about taking it out but I know we will do fine. Harder to find a place to park thou.
Thanks for the input and happy boating.
Jerry B is offline
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
pax2you
3
09-18-2007 09:07 AM
xpx747
08-28-2006 03:55 PM
deboatmon
0
04-29-2004 02:24 PM
later
1
03-03-2004 09:13 PM
