boat runs the stops >
boat runs the stops
boat runs the stops
Old 04-20-2004 | 10:35 AM
CHAOS REIGNS's Avatar
would an oil filter work as a separator ??
like i said -- i checked the number on the filter -- it comes back as an oil filter
or better yet -- what should i use as a separator ??
i don't have an inline fuel filter -- it goes straight from this "separator" to the fuel pump -- through a pressure regulator -- right into the carb
perhaps i should install an inline fuel filter ??
CHAOS REIGNS is offline
Old 04-20-2004 | 10:42 AM
fund razor's Avatar
There is a different part number for the separator, but I don't know how the construction differs from the oil filter.
I have always bought one model number for oil, and one for the water fuel separator.
You might have a really small inline fuel filter after the pump and before the carb. Mine hides in a fitting that doesn't look much bigger than it would be if it was just to connect the line.
But, I don't know what kind/size power you run, so maybe my info doesn't apply.
fund razor is offline
Old 04-20-2004 | 10:45 AM
i'll go take some pic's
i wanna make sure i get this right the first time
back shortly!!!
Old 04-20-2004 | 11:03 AM
well -- it is a separator -- but i don't have a fuel filter
would the separator cause this problem ???
Old 04-20-2004 | 11:04 AM
more
Old 04-20-2004 | 11:05 AM
Old 04-20-2004 | 11:27 AM
Happened to me and I was just out of gas,would idle for a while but would die when on plane.The problem was that the pickup is a little off of the bottom.Actually I have a twin engine setup with two pickups for fuel.One would die before the other,It turned out to be because it was a little higher off the bottom of the tank than the other.
fishead is offline
Old 04-20-2004 | 11:34 AM
so is it worth it -- to replace the separator ??
Old 04-20-2004 | 11:58 AM
common for the sender to be bad and you're actually out of gas. Seen it happen. Was out of gas while reading 1/4 tank
zahndok is offline
