-   -   having idle problem with this cam (https://www.offshoreonly.com/forums/general-q/77317-having-idle-problem-cam.html)
timucin 04-22-2004 04:58 PM
1 Attachment(s)
i was expecting around 1000rpm idle but it cant work under 1500 properly, do you think this cam is hi for 1000rpm idle?
520 cu in.8-71 blown bb
Griff 04-23-2004 12:04 AM
Thats a BIG cam for 520 CI. What's the base ignition timing set at???? More timing will help it idle better.
mopower 04-23-2004 09:12 AM
Went though the same thing with my 540's last year:( Changed cams over the winter. I didn't have enough vacuum at idle to pull fuel once I put it in gear and the rpms dropped some more:mad: .
NOTE: THESE WERE RECOMMEMDED BY COMP CAMS:hothead:
Cord 04-23-2004 10:03 AM
Do you have the idle set so high that the butterflies are open past the slot? I'm wondering if some carb work by one of the gurus wouldn't help.
timucin 04-23-2004 05:04 PM
sorry bros, i worked a bit too much last week to finish this project .
problem was valve settings, fixed and everything is ok now, idles around 900rpm
thnx for ideas and help
