whats the rpm on a 502? >
Old 04-22-2004 | 09:50 PM
migara422's Avatar
Default whats the rpm on a 502?
I have a marine crate engine 435 hp 502, i would like to know what its the maximum rpm i should be running this engine before the hp starts to go down?
thanks in advance
migara422 is offline
Old 04-22-2004 | 10:09 PM
Pat McPherson's Avatar
Max horsepower will be between 4600-5000rpm.
The engine can safely handle about 5600rpm though....
Patrick
Pat McPherson is offline
Old 04-22-2004 | 10:12 PM
migara422's Avatar
So anything above 5000 rpms would be of no speed gain? im really confused when it comes to this.
Old 04-22-2004 | 10:22 PM
Well probably not??? You should try some different props with your engine max rpm in the 4600-5000 rpm range.
I tried a number of props on my boat last Summer.
My boat went faster with a 26p spinning slower than a 24p faster. I am assuming that the engine went past it's peak power with the 24p.
Patrick
Old 04-22-2004 | 10:36 PM
migara422's Avatar
I will try different props in the next few weeks, hope i gain some mph. Thanks for the info Pat.
Old 04-22-2004 | 11:24 PM
Jonas's Avatar
i found that the best rpm spped came at propd for 5150 only spent about 4k on props to get to that #
Jonas is offline
Old 04-23-2004 | 06:43 AM
Do You have a 24' Pantera?
Talk to Jo at Pantera.
He'll likely tell you to start with a 25p Mirage plus or a 26p Bravo one.
You should run about 73mph in fresh water and about 75mph in salt.
Good Luck!
Patrick
25 hors la loi
5
07-18-2005 03:43 PM
CAPTAIN CHUCK
10
09-12-2004 03:50 AM
wwwTOPDJcom
06-10-2003 06:09 AM
stevejohns
6
08-14-2002 04:59 PM
liquid asset
10
05-09-2002 11:52 AM
