-   -   Cool Fuel Cover??? (https://www.offshoreonly.com/forums/general-q/77414-cool-fuel-cover.html)
Blue by You 04-23-2004 04:03 PM
Cool Fuel Cover???
1 Attachment(s)
Anyone know where this goes? Found it under the oil pan. 502 MAG MPI
WHOSNEXT 04-23-2004 04:15 PM
Isn't that a fuel filter cover? if so over your fuel filter.
US1 Fountain 04-23-2004 04:20 PM
Way down under the exhaust manifold on the right side(facing motor). It snaps over your fuel pump on the side.
Blue by You 04-23-2004 04:27 PM
No this one flat... The fuel filter cover is in place. I looked around but didn't see anything.
Blue by You 04-23-2004 04:28 PM
I'm checking it now....
US1 Fountain 04-23-2004 07:22 PM
Blue by You 04-23-2004 07:40 PM
Sweet... Thanks!
obnoxus 04-25-2004 03:22 PM
Put it on a shelf,,, dont bother !! its a pain in the azz to put back on.
Blue by You 04-25-2004 03:38 PM
Got it on with a little help. Glad I looked though, cause my motor mount screw was half way off? Has that ever happened to anyone else? I cranked it back down tight. Should I be concerned?
ragtop409 04-25-2004 04:09 PM
Motor mount screw?
Do you mean the nut on top or below the big pin (bolt) so YES! dont just tighten the top nut down. Your motor is out of line.
If your talking about the bolts that go into the block, yes tighten them suckers up.
Rag's
