Alternators AMP's >
Alternators AMP's
Alternators AMP's
Old 04-27-2004 | 03:22 PM
Reed Jensen's Avatar
From what you have described.... the charging system goes through the ammeter... to answer your second question... yes... if the battery switches are on "both" the charging systems are connected... along with the power to all the accessories... and the batteries.
Reed Jensen is offline
Old 04-27-2004 | 03:40 PM
seahawk's Avatar
Is this ok or should I only use "both" for starting only then switch each battery to that motor.
seahawk is offline
Old 04-27-2004 | 05:44 PM
I prefer to start on each battery.. port on #1... starboard on #2.... Both if the batteries are low... but I have always switched them to seperate batteries while running... my boat was wired with the port charging system powering the port accessories... trim motors etc... and the starboard charging system to the starboard accessories and the cabin power... that way I could run the starboard battery dead while beached... with the port battery in the "off" position... that way I always had one charged battery to start the motors. But... you have to make sure that there aren't any wires connecting the two systems... or both batteries will go dead.
Old 04-27-2004 | 06:30 PM
seahawk's Avatar
Thanks Reed
seahawk is offline
Old 04-27-2004 | 11:44 PM
I hope that helps.... I has so many wiring problems on my boat... I tore out all the wiring and rewired it... talk about a big job... but everything worked... never had any electrical issues... The previous owner had twisted wires together and then wrapped them with duct tape.... talk about a gremlin breeding ground........
satisfied1
8
02-05-2008 08:00 AM
waterblaster
1
07-28-2006 04:53 AM
CN24
26
12-27-2004 08:28 AM
mopower
3
12-09-2002 05:37 PM
