GM Head Bolt Question >
Old 04-27-2004 | 04:07 AM
BAD-HABIT's Avatar
Default GM Head Bolt Question
I just slapped my vortec heads on my sbc. Got all new GM head bolts. The bolts came from GM with a sealer already on them. After reading a similar thread I am wondering.... Do I NEED to add sealer to the factory sealer on the threads or is the factory sealer o.k.? Also if I need/decide to add sealer since the heads all allready on the block (not fired though) can I re-use/re-seal the NEW bolts. Again the I just put the heads on last week. The engine still hasn't been fired. I normally use Avaition sealer but since the GM bolts had a sealer on them I left them as they came.
Randy "Bad-Habit"
BAD-HABIT is offline
Old 04-27-2004 | 08:34 AM
Registered User
You wont have a problem, Aviation sealer is a good substitute. However, ARP`s thread sealer has worked the best for me.
MIAMIBOYZ is offline
Old 04-27-2004 | 07:45 PM
Lester
I always use teflon thread sealant as it works as anti- sieze as well...ARP is also good
Old 04-27-2004 | 11:57 PM
Not sure what kind of sealer the GM bolts have or if the have enough. It could just be an antisieze or lube. Unless you know what it is, then I would pull one bolt at a time, seal it, and then replace it. Felpro recommends this process for a retorque also.
Griff is offline
Old 04-28-2004 | 04:57 AM
BAD-HABIT's Avatar
Well according to Salee Chevrolet the substance is sealer. My local machine shop stated that they were fine to use as is....
BH
BLOWN85
4
04-14-2008 12:22 AM
TeamSaris
05-03-2006 08:45 PM
rush
3
04-13-2005 06:31 PM
Powerboatin
10
02-25-2003 09:27 AM
Dave Schumacher
16
04-30-2002 11:11 PM
