Buffing done!  How to get old pinstriping off!! >
Old 04-29-2004 | 07:59 PM
Default Buffing done! How to get old pinstriping off!!
Thanks everyone for the suggestions on buffing my boat. That 3M Finesse It, did wonders! It was exactly what I needed, even at $40 a bottle! I used a good fiberglass wax after that, and man what a deep shine! I noticed doing this hard labor, that my pinstriping (1/4 inch) was cracking and looking old and sun worn. It didn't even look like a sticker anymore. What is a good way to remove it? I realize I will have to re-wax that area again, but that striping has to go!
justinVIP is offline
Old 04-29-2004 | 08:02 PM
eyezlee's Avatar
3M Woodgrain and Vinyl Stripe remover. Its an aerosol can. I used it to remove old vinyl pinstripes from my aluminum trailer.
eyezlee is offline
Old 04-29-2004 | 08:03 PM
Crazyhorse's Avatar
Go to your local auot refinisher-supplier shop and buy a rubber wheel to do this job. It looks and feels just like an eraser and buzzes the stripe right off. It works best in an air-powerd drill.
Crazyhorse is offline
Old 04-29-2004 | 08:10 PM
Steve_H
ive used a blow dryer before with success.
heat up the vinyl for 20 seconds and it peels right off.
course , if yours is old enough to crack it might not work.
Old 04-29-2004 | 08:12 PM
eyezlee's Avatar
I also used the rubber wheel on the aluminum, but will it work ok on gel coat and fiberglass and not "burn"?
eyezlee is offline
Old 04-29-2004 | 09:04 PM
the rubber wheel is more what I was looking for. The spray on sounds like a mess. I've used the blow dryer before also, but your right, this stuff is too old and cracked. Anyone else know if the rubber wheel will hurt the gel coat?
Old 05-02-2004 | 02:41 PM
Crazyhorse's Avatar
Nope, it doesn't hurt the gel. I used it with great success on my 1980 31' Searay, both the bootstripe tape and the deck tape, both of which were the original 1980 tape.
Old 05-02-2004 | 06:13 PM
87 glass
Default pinstriping
Just did the same thing to my boat and used a heat gun and all the stickers and pin striping came off no problem and my boat is an 87 and the tap is factory.
JIM
Old 05-02-2004 | 07:10 PM
wwwTOPDJcom's Avatar
heat gun on LOW works great
wwwTOPDJcom is offline
GregP
05-28-2005 06:30 PM
CAP071
03-24-2005 10:38 PM
formula31
10-08-2003 08:13 PM
US1 Fountain
6
07-24-2003 09:02 PM
RLW
22
01-06-2003 07:31 PM
