Mechanical meters >
Mechanical meters
Mechanical meters
Old 05-02-2004 | 09:10 PM
SSComp's Avatar
Default Mechanical meters
Do most boats with mechanical gauges use a standard nylon tube or braided stainless?
SSComp is offline
Old 05-02-2004 | 10:13 PM
blown formula's Avatar
xtandard nylon or copper tube.... braided would be outrageous & not needed. None of the pressures are high enough to require it. Not to worry.
blown formula is offline
Old 05-03-2004 | 03:26 PM
38KV's Avatar
Don't use nylon or copper for fuel pressure.
38KV is offline
Old 05-04-2004 | 12:23 AM
I agree with that- I put mechanical fuel pressure gauges directly mounted to the fuel lines at the carbs or efi fuel logs for setting accurate pressures and as a cross check of the electronic gauges on the dash. The only mechanical gauges really needed are boost & water pressure as the sensors don't like water exposure. I was referring to burst pressures as far as the nylon goes (oil pressure, water, boost or even fuel)...... Fatique could be a problem for copper, not so with the nylon.
Old 05-04-2004 | 08:42 AM
SSComp's Avatar
Thanks guys. I was really only speaking of boost, vacuum, and water.
SSComp is offline
shotjock
18
06-08-2010 01:25 AM
waterman
04-02-2006 11:52 PM
KNOT-RIGHT
Detailing, Painting, & Fiberglass
14
10-06-2005 12:25 PM
Tantrum
06-20-2002 01:36 PM
