changing oil in belt driven fuel pump >
Old 05-04-2004 | 06:23 PM
David Haag
Default changing oil in belt driven fuel pump
How do you get out the old oil. Motor is a 454/ 310hp
Old 05-04-2004 | 06:26 PM
There's two plugs on the side, one for filling and one for draining. Depending on what kind of room you have, you can drain it without removal or simply remove, drain and re-fill at the workbench.
Holy Smokes is offline
Old 05-04-2004 | 07:01 PM
David Haag
I only see the plug to check the level. Where exactly is the drain plug?
Old 05-05-2004 | 06:54 AM
DanB's Avatar
Charter Member #71
Some had 2 plugs some had 1, I have both on my twins. Pull them off, tip them over and drain and flush, then replace with gear oil. You'll be suprised at the crap that comes out.
BTW take your belts to napa and they can match them up. I just got all 5 preium belts for mine for 50 bucks.
And you may as well replace the sea pump impeller while its off. I would do this yearly. But then again I'm anal and dont break down on the water.
Dan
DanB is offline
Old 05-05-2004 | 09:43 PM
rbtnt's Avatar
I take my off and tip them over too. Why do you use gear lube instead of engine oil?
rbtnt is offline
Old 05-05-2004 | 11:44 PM
I pull the fuel pump off and use a syringe to suck oil out.If I am doing the impellar I pull the whole unit.Use merc gear oil.If the old oil smells like gas the pump needs replacing.
HARRISONMIRAGE is offline
tewks
0
10-03-2005 08:24 AM
cougarman
2
06-14-2005 08:58 AM
David Haag
4
05-04-2004 08:32 PM
Monty
1
10-21-2003 08:23 AM
WETTE VETTE
4
06-13-2002 01:49 PM
