Eickert exhaust hole location >
Old 05-07-2004 | 09:59 AM
merkruzer
Default Eickert exhaust hole location
600 volvo with Eickert headers and thru hull tailpipes mated to a bravo setup. I have this diagram of the dimentions, but cannout get the actual cutout locations.
Eickert couldnt verify if it was a std bravo cutout, and had me contact innovation who had the same info as Eickert. The engine and transom are not in yet and I would like to do this prior to the install. Who is good with geometry.......I only want to cut once
Old 05-08-2004 | 05:15 PM
merkruzer
Noone has put eickert headers with thru hull tail pipes on their boat?????
If so did they hit the stock bravo holes or had to be modified?
If they do fit stock bravos locations who has the measurements from crank centerline
Old 05-15-2004 | 08:55 PM
bob
Charter Member #40
Default Re: Eickert exhaust hole location
I have done a couple. Give me a call Bob-856-678-9313.
bob is offline
Old 05-16-2004 | 03:31 PM
blue thunder's Avatar
I just installed two set and they did hit the standard bravo cutouts. They weren't perfect, but close enough for the rubber connection to compensate. I run edelbrock aluminum heads so that might have been why they did not hit exact. They were about a 1/4" low all the way around, which isn't bad.
BT
blue thunder is offline
SCANDINAVIAN
13
07-25-2018 01:30 PM
Michael1
1
05-11-2007 02:20 AM
Mike L
1
07-31-2005 07:21 PM
Dave1972
07-10-2002 05:17 PM
