Leak Down Test Results >
Old 05-10-2004 | 05:47 AM
cig1988's Avatar
Ran the test again on the cylinder in question once cooled down. Back to 35%, Looks like its time to get out the wrenches.
As far as the milkshake, I noticed after running for 45 minutes more than normal steam started coming out from the even bank.
cig1988 is offline
Old 05-13-2004 | 01:43 AM
Pull the intake manifold and check the gasket area where water ports are. Most common cause of water in oil. It will squirt water under pressure into intake valley area and cause milky oil and creamy oil up in the valve cover. Check this first Steve
OffDuty is offline
Old 05-16-2004 | 07:50 PM
cig1988's Avatar
Default Re: Leak Down Test Results
Offduty, Checked that as well. Cleaned up the surface and ran a straight edge. Off the top of my head I dont remember the exact clearance but was very slight.
cig1988 is offline
articfriends
17
04-28-2007 12:31 AM
rssteiny
9
02-19-2007 04:29 PM
cherrycobalt262
05-31-2006 02:20 PM
scottsumrall
12
08-13-2004 02:41 PM
