30 or 32 props >
30 or 32 props
30 or 32 props
Old 05-10-2004 | 07:17 PM
Default 30 or 32 props
had my 32 thunder out for the first time the rpms were hitting 5500 with hp 500s and 30 pitch props should i put on the 32s and run it at 5200, and i should pick up speed wright.
whats your thoughts
thanks
rssteiny is offline
Old 05-11-2004 | 08:26 AM
HOUSTONPROP's Avatar
Default 30 or 32's
I would try them both if you can ,then make your decision,you may want to stick with the 30's and add 1' pitch to them ,and a touch of cupping ,this will keep they midrange acceleration very fast.let me know if we can help or lab a pair for you.Darin
HOUSTONPROP is offline
Old 05-11-2004 | 12:39 PM
throttleup's Avatar
rssteiny,
The Hp 500's Rev Limiter should be at 5300. Have you had the Rev Limiter upped?
Because of our extensive experience with the HP 500, in offshore racing, the max HP is at 5250, just prior to hitting the Rev. This is were you would prop the boat for max top end.
The 32P props should run at about 5100 RPM assuming the 30P's are true and your tach is accurate.
If the RPM is a bit low with the 32P reducing the cup will adjust the RPM. Essentially dialing the prop in. Additional cup may not necessarily be the adjustment you need.
Feel free to call me any time.
Julie
Throttle Up Propellers
throttleup is offline
Old 05-11-2004 | 02:53 PM
Default Re: 30 or 32 props
whats your thoughts
thanks
I would say lets try adding some cup to the 30's keeping them thick -/re-balance the props and satin finsh,I bet this would work great and you will have some excellent durable props.
80.00 each plus shipping>let us know if we can help,Darin
the 32's will drop 400 rpm possibly more.
Old 05-11-2004 | 06:38 PM
ill try the 32 see where im at then rework the 30s if need be.
thanks and ill be in touch
rssteiny is offline
mcprodesign
06-08-2008 07:54 PM
diggster69
Prop Talk
2
02-06-2008 07:59 PM
HOTTZU98
3
05-13-2005 07:43 AM
raiseyourdrive
09-15-2004 08:23 AM
dougB
0
05-06-2003 04:16 AM
