Gaffrig Switchable Muffler ? >
Old 05-16-2004 | 08:38 PM
Default Re: Gaffrig Switchable Muffler ?
For $250.00 you will surely get the small mufflers and no pump or plumbing hardware. For me, I had the Bandit's. They really did look great. Didn't fit a 4.00" standard exhaust pipe as advertised though. To their credit, they did replace them with four that were sized correctly. The replacements actually would fit over my pipes which are long through transom Stainless Marine risers. After about a month, they started randomly sticking shut.Not good. Sometimes one, sometimes two, sometimes three. About then, one of my new Gaffrig oil pressure gauges started sticking at 0 lb. Not too much later my new Gaffrig shifters with trim in the handle started rubbing/grinding badly. I now have CMI switchable mufflers that work great, Zero Effort shifters that work great and Stewart Warner gauges. Still want Gaffrig mufflers ? Maybe Mike Livorsi will get things going in the right direction with the new name and such. They sure sell a lot of equipment. Maybe I just had bad luck !
deboatmon is offline
Old 05-17-2004 | 05:36 AM
dyno's Avatar
Charter Member #655
Bummer
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 05-17-2004 | 07:15 AM
bglz42's Avatar
The boat I just bought came with a set of those mufflers. They look great, but my compressor is frozen. Anyone have a Gaffrig compressor laying around?
bglz42 is offline
Old 05-27-2004 | 04:58 PM
GAUGETHIS's Avatar
Offshoreonly Advertiser
I Have A Used Twin Engine Set ( 4 Mufflers) Of 4 Inch Transom Mount Bandits For 1000 And A Twin Engine Set Of 4 Inch Clamp On Powertip For 650. Does Not Include Pump Hose Fittings Ect.
GAUGETHIS is offline
NJDave
11
09-03-2008 12:05 PM
NJgr8ful
Swap Shop
6
08-12-2008 10:40 AM
jeff32
24
02-21-2006 01:56 PM
dean campbell
03-25-2005 02:33 PM
Kokopelli
17
12-04-2003 05:40 PM
