-   -   Hitch ball mounts, what are you using? (https://www.offshoreonly.com/forums/general-q/79237-hitch-ball-mounts-what-you-using.html)
tssteph 05-17-2004 10:06 AM
What hitch ball mounts are you using? Hollow ball mounts are rated at 5000 or 6000 lbs depending on the manufacturer. 2 5/16 trailer balls with a 1 inch shank are rated at 5000lbs or 6000lbs. Solid ball mounts are rated between 10k and 12k lbs. 2 5/16 balls with a 1 1/4 shank are rated at 10k lbs. Sure seems like a lot of us may be towing with the wrong ball mount and ball setup, I know I have been. I only noticed all this when I went to get a different drop hitch for my new boat and new truck combination. All along I have been towing my boat, car trailer, and camper with a 5000 lb max trailer weight setup.
