bravo 1 drive gear cases ? >
Old 05-17-2004 | 07:36 PM
26sonic's Avatar
Default bravo 1 drive gear cases ?
need to replace my bravo 1 gear cases 1:50 ratio rh upper and lower due to corrosion from my merc cathode system not working ! who can i get them from the cheapest ? is there such thing as re-furbished cases ?
26sonic is offline
Old 05-18-2004 | 05:30 PM
26sonic's Avatar
Default Re: bravo 1 drive gear cases ?
ttt
26sonic is offline
Old 05-18-2004 | 05:37 PM
New Bravo 1 Complete Upper With 1.50 Gears $2195.00
BayshoreP is offline
Old 05-18-2004 | 06:13 PM
Mr Gadgets's Avatar
Charter Member #601
Try Sterndrivspec..
Chris Martin.. 315-623-7642.. he may be able to help you..
Good luck
Dick
Mr Gadgets is offline
Old 05-18-2004 | 07:03 PM
Mbam's Avatar
Offshoreonly Advertiser
I have a couple of new ones I will sell for $900 each, but what year are your drives?
Mbam is offline
Old 05-18-2004 | 11:59 PM
26sonic's Avatar
mbam my drive is a 1998 bravo1 , i need the upper and lower cases only , what price on both ?
26sonic is offline
Old 05-19-2004 | 06:31 AM
Mbam's Avatar
We can do the uppers for $971. I hate to bring this up, but how much power are you running? Might be time to consider new upper gears too. You should also give Chris a call and see what he has. I don't have any rebuilt drives at this time, but it might be a better way to go.
Mbam is offline
Old 05-19-2004 | 11:54 AM
26sonic's Avatar
mbam (marc) i am running stock 1998 502 efi. remember i'm looking for just to replace the cases(housings) not the gears , i'll use the gears from the original drive just want to transer them over to new shells.
26sonic is offline
Old 05-19-2004 | 04:43 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Be sure to price the reassembly and setup before commiting to just buying new cases. I had a quote of $400 each just to reassemble my lowers that I had apart. With you considering 2 cases, both needing reassembled, shim kit and new seals, it might pay to buy a complete rebuilt or a slightly used drive.
US1 Fountain is offline
Old 05-19-2004 | 09:52 PM
Mbam's Avatar
What he said, it can however make sense if you are doing the work yourself.
Mbam is offline
