Excessive throttle pumping required to start >
Old 06-01-2004 | 10:43 PM
Default Re: Excessive throttle pumping required to start
There are two well plugs below the main jets on a Quadrajet that leak. This is a well known problem. Rebuild kits even came with a foam block that you put in to stop the leak. The fix is to remove the throttle plate assy, and you will see the two plugs sticking down. Smear a good epoxy (Like JB Weld) on them, let it dry, and reassemble.
It's that easy.
Liberator21 is offline
duksrule
5
07-24-2006 01:41 PM
alter ego
4
04-17-2004 09:21 PM
