Banjo Fitting >
Banjo Fitting
Banjo Fitting
Old 05-29-2004 | 11:24 PM
merlin540
Question Banjo Fitting
Where Do You Get That Slick Banjofitting That Goes On A Gm P/s Pump Pressure Fitting For Hyd Steering Its A 14mmx1.50 Bump Tube Fitting Now And It Hits The Cyl Head I Cant Find Ther Part #to Order It Thanks
Old 05-30-2004 | 07:31 AM
Elite Marine's Avatar
Default Re: Banjo Fitting
Summit. I'll check my records and try to get the part number.
Elite Marine is offline
Old 05-30-2004 | 07:33 AM
Aeroquip part #aer-fcm 2608 from Summit.
Old 05-30-2004 | 10:38 PM
p4-33's Avatar
Got mine from Latham. They have a regular size and low profile ones for tight spaces. These need to bolt on before you install the pump on the brackets. I also had to order PS/alt brackets from IMCO to raise the pumps high enough to clear my Powerflows.
Brian
p4-33 is offline
Old 06-01-2004 | 08:53 PM
merlin540
thanks
Old 06-01-2004 | 09:01 PM
getreal's Avatar
I have them in stock.
www.getrealperformance.com
getreal is offline
docmanrich37
05-30-2007 09:46 AM
BadDog
1
04-09-2005 07:40 AM
Cord
12-11-2003 08:04 AM
Raypanic
11
09-20-2003 07:52 AM
