RTECH Supercharger on 502 MPI
#92
Originally Posted by hotlavey
Chase, another question. Aside from the water inlets, what are the differences between that drive and my XZ drive?
The lower I have has 128hrs on it, fresh water, 1.5 ratio. It is a swap you can easily do in your driveway. There is a total of 7 bolts. 3 nuts on each side and a bolt in the trim tab. Drain oil, remove 6 nuts and 1 bolt, drop lower unit, replace lower unit, install bolt and 6 nuts, fill with oil, done.
Give me your zip and I can get shipping charges.
I'd also be willing to buy the lower unit back, minus shipping charges, if it doesn't solve your cooling problem for some piece of mind on your end.
#93
#94
HotLavey,
have they checked for a restriction anywhere. We have the same lowers and with a high X dimension I'm pounding well over 60 lbs if I don't regulate it. If you open your 4 nose holes to 5/16, this will be in effect identical to the single 5/8 hole found in all of the IMCOs and such.
Your pressure will be derived from the ram effect on the nose so I don't know that the big ole dual stage will help you at all. It still has to pull the water from the nose. You may also (per Dustin) want to install a 5/8 restrictor plate where your thermostat would normally go. This will also help keep the pressure up where Whipple likes it.
Don't get frustrated and start throwing more money at it YET. I think your issue can be resolved without much additional cost.
Good Luck,
Dave
Good Luck,
Dave
#95
Dave,
Good to hear from you again. I hope you're having a great summer. I opened up the nose inlets as you suggested a while back. Didn't seem to make much difference. The restrictor plate sounds interesting. How does that affect the flow? We noticed that the intercooler dump has a pretty strong flow at idle and the dump from the heads is pretty weak. When the boat accelerates the head flow seems to stop. It's really hard to see clearly tho as there is a lot of exhaust water and turbulence back at the transom. At idle the pressure shows zero, although I am getting a strong flow from the intercooler dump and less from the heads. The only mod that really made a difference was plugging all the side inlets. Max pressure went from 10 to 15 at WOT. As for the dual stage, another pick up is also installed along with a sea-strainer.
Is that restrictor plate available through Whipple? Tell me a little more about it if you have time.
Thanks again for your help-
Tom
Tom
#96
Tom,
Great summer to date
Thanks.
The restrictor plate is a simple stainless or aluminum plate that is the same size as a thermostat. It would just go where your thermostat went originally. Just a flat piece with a 5/8 hole drilled in it. I’m sure Dustin or Gary Teague stocks them or can whip one up for you easily enough; Probably only about $5. This just keeps the pressure up in the block by restricting the outlet of the water a bit. This is the size that they feel works the best all around for their setups and creates good pressure. This also helps to eliminate steam pockets along with your rear dumps. I assume your rear dumps are only ¼” right?
I was getting a zero reading on my gauge at idle also. I purchased a 5 lb check valve with ¾ fittings and installed it on the out let hose of my intercooler. This keeps the water running through the block at idle and not through the intercooler. As soon as I start to plane I have intercooler flow and at idle I have good water flowing though the block to cool it after those hard runs.
Hope this helps…
Dave
Thanks.The restrictor plate is a simple stainless or aluminum plate that is the same size as a thermostat. It would just go where your thermostat went originally. Just a flat piece with a 5/8 hole drilled in it. I’m sure Dustin or Gary Teague stocks them or can whip one up for you easily enough; Probably only about $5. This just keeps the pressure up in the block by restricting the outlet of the water a bit. This is the size that they feel works the best all around for their setups and creates good pressure. This also helps to eliminate steam pockets along with your rear dumps. I assume your rear dumps are only ¼” right?
Hope this helps…
Dave
#97
Dave , I just spoke with the installer and he did install the restrictor plate in my engine.
The rear dumps are 1/4".
After talking with the rebuilder we decided to intall a seperate pick-up for the intercooler along with a check valve to limit the pressure, as well as a sea-strainer. No dual-stage water pump at this time. I hope this will solve the problem.
We just returned from a week at Lake Mojave out of Cottonwood Cove(on a houseboat). I have never seen so much flat water in my life. The ski hissed, it was like skiing on a mirror. The problem was self-control with the throttle. At 15# pressure we had to stay out of the boost and it was tough. I buzzed it to 76 mph when I was testing max pressure and had 4 lbs of boost and backed out real quick. I could run 60-65 with no boost so that's where we kept it. Heading for Mead in Sept for the Regatta and we should be good to go then.
I'll let you know.
Tom
I'll let you know.
Tom
#98
Hey Tom,
Sounds good. You won’t need a check valve though. Beings you can’t run both of the pickups with one pump, one of the pickups will be feeding the intercooler by ram/forced pressure only and it won’t flow until your on plane anyway. No desperate need for a sea strainer on this water source because it never draws.
The sea strainer will be inline with the pickup to pump/motor line.
Been dying to try Mojave. Looks fun and doesn’t have the water issues we’re dealing with in these parts. Email me and let me know what you thought of it.
Also, I do have a transom mount pick-up. Polished from Stainless Marine if you haven’t ordered one yet.
Dave
[email protected]
Dave
[email protected]
#99
Dave,
If you are able to rent a houseboat out of Cottonwood, do it. I have never seen such a huge amount of glassy water in my life. We did have some wind chop at times but most of the time it was glass. Catherine's Landing area can get very busy and rough, that's why we opted for the houseboat and Cottonwood cove. There are no other facilities on Mojave except for Catherine's, Cottonwood, and Willow Beach. Cottonwood and Willow are well above Catherine's(i think approx 20 miles for Cottonwood, and another 14-15 miles to Willow)We have already reserved the 70 footer for next year. We did it early as they only have one of those. This year we had the 59'. It was great but we have a few more people going next year so that's why the bigger one. Big problem there- gas was $3.20/gal. Yikes! Not going into boost probably saved me a lot of money. Oh, another thing, very few boats in that area during the week. We may have seen 5-10 all week but weekends are busy there.
Thanks for the pick-up info, I'll take a look.
Tom
Tom
#100
Originally Posted by tomcat
The larger injector body requires a bit of work with the Dremel on #1 and #8 cylinders. You have to plug up all the port bosses so the chips don't go into the intake manifold. The #7 hole in the injector rail has to be opened up from 9/64" to 13/64". This is a bit tricky. All the other injector holes are full the O-ring diameter all the way up into the top (supply) side of the fuel rail. But the #7 hole is only 1/2 as deep because of how the supply and return lines are plumbed into the back of the fuel rail in this vicinity. So there is a small hole drilled on an angle from the #7 hole into the top of the rail. This needs to be opened up to supply enough fuel to the larger injector. Finally, everything in the fuel system is together and subjected to a leak test. This is a good time to set the base fuel pressure to 50 psi.
