-   -   Bleeding disc brakes (https://www.offshoreonly.com/forums/general-q/80840-bleeding-disc-brakes.html)
muffman 06-09-2004 01:46 PM
Re: Bleeding disc brakes
All these creative methods will work just fine. I use a syringe with a small vacume line on the end. Fill it up with fluid, open the bleeder and inject the fluid in. If you hold the syringe vertical you can also suck the fluid from the master cyl. You can pick one up from your local pharmacy. Mine is about 3/4 in diameter and 6" long. It should cost less than 5$
