Bravo 1 Lower gear case >
Old 06-11-2004 | 09:21 AM
thunderusone's Avatar
Default Bravo 1 Lower gear case
How much play should the vertical shaft in a standard Bravo 1 lower have? I bought 2 (Rebuilt) lowers from 2 different places and I can pull the vertical shaft up nearly 1/4" on both of them. This changes the lash in the gears.....I did not think that anything in the upper gearcase held pressure down on the shaft. Is that normal. Another friend of mine had one rebuilt and you can't move his at all. And of course I am getting the "thats normal" from who I bought the lower from.
thunderusone is offline
Old 06-11-2004 | 10:24 AM
Default Re: Bravo 1 Lower gear case
Help!!! I am trying to figure out whether or not to run these things this weekend...
Old 06-11-2004 | 10:57 AM
Mbam's Avatar
Offshoreonly Advertiser
When the drive is bolted together the upper clamps a retainer that locates the upper bearing. You can't check it without the special tool that simulates the upper.
Mbam is offline
Zanie
Swap Shop
3
02-03-2011 07:29 PM
thedonz
Wanted
0
05-10-2008 04:45 PM
WAGS382
Drives and Lower Units
1
08-11-2007 09:35 PM
pkspx
3
03-27-2007 07:45 PM
AIR TIME
01-14-2006 12:33 PM
