My engine Water Pump is weeping...should I be? >
Old 06-15-2004 | 02:43 AM
skygod's Avatar
Default My engine Water Pump is weeping...should I be?
There is a stain around the weep hole, and it is weeping. Does this mean I need to replace it immediately? About how much?
Thanks,
Carl
Baja History
2000 29 Outlaw 2x454 mags (sold)
2000 25 Outlaw 502 (moved up to 29 OL)
1998 232 Islander 7.4 (got the 25 OL)
Tow Rig
04 Excursion EB PSD 4x4 6" lift 35's
MY PICS: http://community.webshots.com/user/skygod73
skygod is offline
Old 06-15-2004 | 05:04 AM
Audiofn's Avatar
Charter Member #232
Default Re: My engine Water Pump is weeping...should I be?
Yup it needs to be replaced. They are not so bad. Last I replaced them I got them from NAPA for I think 140 bucks or so. Labor is a very simple thing to do. Should not be a bad/expensive fix. You have to use a marine one as it has a stainless impeller.
Jon
Put your best foot forward!
Audiofn is offline
Old 06-15-2004 | 05:24 AM
Iggy's Avatar
Check out BoatFix.com .
Circulation pumps run 66.54 to 105.00.
Bought mine from there two years ago.
Iggy is offline
Old 06-15-2004 | 07:21 AM
Scott's Avatar
Charter Member #30
Both of mine weep just a little bit when first started then stop after warm up. They have always done this and never seemed to hurt a thing. I can only assume this is because of higher water pressure until the T-Stat opens.
I have Steps & Bubbles!
Scott is offline
Old 06-15-2004 | 09:09 AM
BajaRunner's Avatar
ive got one leaking. the only reason boats can get away with this is we have bilge pumps and an unlimited water supply
BajaRunner is offline
Old 06-15-2004 | 09:51 AM
robyw1's Avatar
uhhh.... eventually the pressure will blow out your front seal if allowed to go on this way. been there, done that. Bilge pump-smilge pump, if your waterpump shaft seal goes then you WILL over heat. I will be in Austin in a couple of weeks. I hope I won't need to tow you.
Roby
robyw1 is offline
Old 06-15-2004 | 11:18 AM
euby's Avatar
yep..for the money i would replace it now... or you'll be sorry later
euby is offline
Old 06-15-2004 | 11:26 AM
BajaRunner's Avatar
Roby
no i agree it needs to be fixed, you just have a little longer to do it. if it was in a car, you would be on the side of the road with no antifreeze.
dont worry, i plan on doing it this weekend. ive just procrastinated a little more than usual. give me a buzz when you get into austin.
Old 06-15-2004 | 01:39 PM
skygod's Avatar
Yeah I figured it was toast. I'm just trying to decide if I need to do it before we go to lake Mohave this weekend. I am just finishing replacing both drive trim indicator cables. This is the first boat I have done all the work on. Sometimes it's a PITA but it sure saves $$$. I have learned a lot thanks to my trusty service manual. The job looks pretty simple. I am doing trailer brake shoes on an axle before also. I started my spring project list a month late. Thanks all!
Carl
Baja History
Tow Rig
skygod is offline
Old 06-15-2004 | 07:02 PM
NEXTASEX
Int he classifieds they have a dealer selling new marine gm water pumps for i think 75$ for BBC.
